2G What’s this connector for??
Mamuthemechanic
Oct 13, 2022
Atlanta, Georgia
Quick summary. Installed a OHM Racing tucked harness in my 2g. Everything is fine and car runs as it should, but I have one connector behind radio that is not connected to anything.
Oh and I did pull the old harness out before the new one, just don’t know what this is used for? Any help would be appreciated
RIGHT SIDE OF BIGGER BLUE CONNECTOR THE SMALLER BLUE ONE?
P.S This is not my harness in pictures using it as a reference
RIGHT Side smaller blue connector!
If I remember correctly, the blue connectors connect the engine harness to the chassis harness.
Yes i understand that, thanks , the bigger of the two I have plugged in, it’s the smaller one on the right , I’m trying to figure out its use and what it’s for I don’t have the female side anymore to connect
It’s cruise control related and more utilized in vehicles with automatic transmissions. If the OHM harness is a race harness, it makes sense to have deleted this connector.
B-64, Body Wiring Harness and Control Wiring Harness Connection, 10-position blue connector
Pin 1 - Blue with red, A/T ONLY, pin 17 of J/B connector B-66 (Fuse 15, 10A) to pin 3 of Auto-Cruise ECU (B-29)
Pin 2 - Red with white, pin 4 of overdrive switch (C-14) to pin 11 of Auto-Cruise ECU (B-29) OR pin 37 of ELC 4-Speed Auto TCM (B-62) for vehicles without cruise
Pin 3 - Yellow with red, pin 3 of Throttle Position Sensor (A-63) to pin 4 of Auto-Cruise ECU (B-29), with branch off to pin 87 of Engine Control Module (B-56), and to Auto Trans and MFI System
Pin 4 - Red with yellow, pin 10 of Auto-Cruise ECU (B-29) to pin 37 of ELC 4-Speed Auto TCM or intermediate connector between B-64 pin 2 and B-62 pin 37
Pin 5 - A/T ONLY, pin 1 of Auto-Cruise ECU (B-29) to pin 1 of Starter Relay (B-96), with branches to ignition switch or theft alarm starter relay, MFI system, and pin 5 of Starter Relay (B-96)
Pin 6 - Light green with black, pin 4 of Stop Light Switch (B-06) to pin 1 of Auto-Cruise Control Vacuum Pump (A-105), with branch off to pin 25 of Auto-Cruise ECU (B-29)
Pin 7 - Blue with black, pin 3 of Auto-Cruise Control Vacuum Pump (A-105) to pin 13 of Auto-Cruise ECU (B-29)
Pin 8 - Blue with orange, pin 4 of Auto-Cruise Control Vacuum Pump (A-105) to pin 26 of Auto Cruise ECU (B-29)
Pin 9 - Blue with yellow, pin 2 of Auto-Cruise Control Vacuum Pump (A-105) to pin 12 of Auto-Cruise ECU (B-29)
Pin 10 - Brown with red, pin 2 of Throttle Position Sensor (A-63) to pin 5 of Auto-Cruise ECU (B-29), with branch off to pin 84 of Engine Control Module (B-56) and to Auto Trans and MFI Systems
