went to dyno and not happy
baxsom
480
5
Jul 10, 2004
san antonoio, Texas
so i went to the dyno today
first run i had the profec on lo boost just to start off on the safe side
it hit about 7.5 psi, 202 whp and 219.8 fp of torque.
air fuel was a flat 10.0
i am not sure on the air fuel but the tech said it was rich and i could afford to turn up the boost some
so i did a run on high boost
this is where it got interesting
you can see the max hp and torque on the attachment but what concerns me is the boost surge
as you can see at about 4500 rpm's the tach would go up and down
but as you can see the air fuel is still at 10.0 so it is not fuel cut or detonation
i noticed on the way home that the gain on the boost controller was set to 50%
so i was thinking could it be spiking, hitting the boost limiter that i had set to 13psi and dropping the rpm's?????
i know i should lower the gain and try again but now i am a little nervous about running it that hard
Are you still using the craptech FPR from Hahn?
If so you need some fine tuning from a SAFC2 and get rid of it and buy a SFMU or FMU w/1:1 fpr.. That thing sucks ass ( I wasted two hours of dyno time messing with that POS)
You can bring your A/F ratio to around 11.6...
You need some smoothing on that dyno slip and show the RPM #'s throughout the graph....try to rescan it.
Don't worry about the numbers it is still untuned.... :thumb:
yes it still is the craptech
i was thinking about an aeromotive 1:1
for a while i was going to get the apexi afc but decided to get the portfueler instead
mainly for the fact that it is easier to pass a sniffer test with the portfueler
yes, turn the gain down some. the profect b spec II is a little difficult to tune at higher boost levels. it took me a couple hours to get it right on high boost without any weird shit going on.
get ride of the cartech.
Sup guys!Just took a loan out on my house to fix up my car.buying a hahn stage to with front mount,What else should i do?I want to make it as fast as my 1g running 14 lbs o boost..Also only 5 grand is going to the fast goodies the rerst is going to everythinhg else.
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
