going to dyno on Thursday...
DSM-ZERO said:
I haven't seen Suieclipse post in a long time
Motor Modifications::
Standard 420a Motor Bored .020 over
JE Pistons
Eagle Extreme Rods
Titanium Springs and Retainers
Stainless Steel Valves
Crankscraper
Melling Oil Pump
Ported and Polished Head
Modern Performance 60mm Throttle Body
60 Degree Thermostat
Unorthodox Cam Gears
Unorthodox Alternator Pulley
Unorthodox Crank Pulley
3" Turbo Back Exhaust - No Res - Not Cat
Dual Circuit Oil Cooler w/ Oil Filter Relocation Kit
Oil Catch Can
Turbo Modifications::
Hahn RaceCraft Super 20G Turbo
Hahn RaceCraft 3" Eliminator Downpipe
Hahn RaceCraft FMIC
Hahn RaceCraft Fuel Cut Defenser
Hahn RaceCraft Portfueler System
- Aeromotive 1:1 FPR
- 230cc Primary Injectors
- 440cc Secondary Injectors
- AIC
Greddy Type S BOV
Missing Link
Autometer Electronic Fuel Pressure Gauge
Autometer Electronic Oil Pressure Gauge
Autometer Air/Fuel Gauge
Autometer Boost Gauge
Autometer EGT Gauge
TechEdge Wideband / Datalogging Unit
Apexi Rev/Speed Meter
Apexi Turbo Timer
Greddy Profec B Spec II Boost Controller
Ignition Modifications::
MSD 6211 Ignition
MSD Tachadapter
MSD Coil Pack
MSD RPM Activated Switch
Nology Hotwires
NGK Iridium Plugs
Drivetrain Modifications::
2002 Neon Transmission 3:55 Gear Ratio
Phantom Grip LSD
Clutchmasters Stage 4 Clutch
B & M Short Shifter
Upgraded Shifter Bushings
Phantom Grip LSD
Suspension Modifications::
Tokico Illimuna Struts
Eibach Sportlines
Front & Rear Strut Bars
OBX Rear Lower Tie Bar
RM Sway Bars
Energy Suspension Bushing Kit
Sprint Camber Kit Front and Rear
Stock 98 GSX Wheels w/ Falken Tires
Brembo Type Cross Drilled & Slotted Rotors
EBC Green Stuff Pads
Appearance Modifications?:
EVO 3 Front Bumper
Vis Z3 Fenders
Functional Hood Pins
PIAA 40 Series Driving Lights
Tenzo Type R Racing Seats
Electronics Modifications::
Custom Built In Car Computer (from MOCCI BOX)
7" Touchscreen
MB Quart Gold Series Fronts
Eclipse Rears
(2) Rockford Amps
Custom Hatch Box
SBstar said:
sheesh how much cash do you have into your car? I think you might want to upgrade to at least 550 cc injectors sometime in the future. Looks good though. You gotta take it to a track and post a time slip on here.
he's got 2 injectors per cylinder, so he's way above 550cc injectors dude. Good luck siue, been looking forward to this moment
My question is how do you do several pulls on a dyno and call it "untuned". If you did more than one baseline pull, which you did then it is not "untuned".
we weren't tuning that day. didn't touch the portfuler box, cam gears, or timing. we only had enough time to tune the boost controller. the greddy spec II took awhile to tune.
in effect. its untuned. i think i know when a car is tuned or not. don't be an ass just because you can be.
First of all, how the heck did you spend all your time "tuning" a boost controller. Second of all you say you know when a car is tuned or not but yet you made this post on 2GNT(and I quote):
siueclipse said:
well, right now because i have a ported and polished head, my 20g doesn't hit full spool till 4500rpm which is why im going twith the larger turbo. my guess is that with a larger turbo the head will fill with air faster so my spool should go down.
I'm not being an ass here, just pointing out that people don't spend all day at the dyno setting a boost controller. You made 337hp tuned deal with it. Make more hp but please don't make more excuses.
I think the whole problem is the portfueler... Why would you spend the money for a tuned(?) box and secondary injectors when you can just get a standalone with bigger (4) injectors and tune it based on your setup?
I think it is a waste of money :thumbdown
jesus youre an idiot. i didn't spend all day at the dyno, i spent 2 hours. a lot of that time was running to autozone to get a new lower radiator hose and i didn't even pay for the dyno time. obx radiator hoses suck. haha It was my first time dealing with an electronic boost controller and it took me some time to get it figured out.
We wanted to mess with the fuel maps but didn't because honestly, we didn't understand it which is why im going to HRC on Feb. 3rd for a good tuning. During the dyno runs we did make, we are only getting a baseline and making sure the AFR's were correct for around town driving. Anytime I make a change, I go back to the dyno.
Again its not tuned you moron. The map that is on the portfuler is the base map HRC configures for you, which still needs to be tuned. The cam gears haven't been touched yet and still rest at their manu's position.
We also never got to up the boost past 21lbs because I wanted race gas, the car will take up to 27lbs of booost. So how is the car tuned for its full potential?
So again, exactly how is the car tuned?
Im done with this discussion. You need to quit worrying about what other people do with their cars and start working on your own. You need to stop coming in the NT/ Turbo section and be an ass when you post. You are a classic example of the 4g63 asshole that nobody likes.
