Weird thing happened when i installed my ac belt
eagletalonesi84
102
Jun 16, 2005
Clear Lake, Iowa
Ok after i got done installing my ac belt wierd thing started to happen. My idel is really like like below 1000, when i put it in reverse it grinds, it's hard to shift gears. What is goin on with all of this.
First of all grammer is your friend.
Focus: One problem has nothing to do with the other, first check the fluid levels in the trans. If it is low then top it off, if it is not low then try changing it with fresh gear oil. If that doesn't work you probably have synchro problems. Next, does the idle fluctuate or does it stay at one low idle?
    • Sdcryan1
