2G weird noise from valve cover/connector identify
ErikTande
Supporting Member
1,522
595
Dec 17, 2012
Centennial, Colorado
What's this connector? blue and black above the heater hoses on the firewall.
also, it sounds like there is a socket in my valve cover. i'll pop it off later tonight.
I don't recall seeing a blue connector on the firewall in my 1998, and I've had the engine out a few times recently, but there are quite a few unused connectors on mine that are taped or zip tied to the harness from the factory. The only items mounted to the firewall in that location are the various emissions solenoids, the injector resistor pack, and the cruise control unit. In my experience with other platforms, a blue connector is often some kind of diagnostic feature in the engine bay. For example, Mazda puts a blue two pin connector similar to that one in the engine bay with GND and battery +12V (shown below) to be used for powering equipment like a timing light since the battery is in the trunk on the Miata. I'm going to guess it's something along those lines.
Sound is broken on my PC for a bit but I'll try to listen to the video soon.
Leave that blue connector alone! I think it is some sort of diagnostic plug. I had removed mine from my 1998 GSX years ago when I had pulled my engine out for a rebuild. The result was that it was only firing on 2 pistons (1 and 4) and couldn't figure out why. Tried everything to fix it and only when I reconnected/resoldered that plug back on did it fix it!
I believe one is to jump the fuel pump (black) & the other is for bypassing the idle control (blue) for setting idle. Both for diagnostics with the OEM ECU.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
