Eagle96TalonTSi
- 292
- 0
- Oct 9, 2012
Crowley,
Texas
Investigating a weird clicking noise in my right wheel when lightly braking and found the rubber case broken over what I believe is a joint. Could this be my clicking noise? I dont think its suspension because when I brake hard there is no noise, only braking softly when the suspension is under no stress.
The other pics are the bottom end of my motor/transmission. I do have a weak clutch and am replacing it soon, and the fluid appears to have two consistencies. The first is clutch fluid. It is clear and smells like hydrolic fluid. The second is dark brown/black and I couldnt tell what it smells like. Im assuming its oil.
These two oils are literally coming from what seems like the same area and I am not sure of the cause.
I never have leaks coming from under my car, nor does it leave spots in the driveway or parking spots. What kind of issues am I looking at here?
Ill go pick some up right now and get it cleaned up and watch it for the next few days.
