Mike Marnik
- 349
- 6
- Mar 5, 2004
Omaha,
Nebraska
Ok so ive finally got my car back up and running after a short in one of the wires to the radiator fans which goes back to the ignition wire. Well ive noticed that if i sit at a light for 10 sec or so and the coolant temps drop to like 190-195 and i take off and give it some gas (not wot) the knock will go up. I wont even be hitting more than 5 psi but once the coolant temps go back up to 197+ the knock completly goes away. I also notice this when cold start the car and go drive that it will do it at only partial throttle. It seems like some kind of phantom knock to me. The only real bad thing i can see about this is when im at the track this spring/summer and sitting at idle while waiting in line and the engine being below 197. The car will bog horribly (timing being pulled) untill it get to temp then the knock dissapears and the car pulls like a raped ape. Any help would be appreciated.
TIA,
Mike
TIA,
Mike
