Knock Sensor, Temp. Ideas
TSiWarrior
300
10
Feb 17, 2005
Detroit, Michigan
I'm going out this weekend with some other talons and I've gotta have my car running awesome. I'm short of cash so I cant get a new knock sensor right now. I'm only going to be running 15-17psi on race gas, so I know my engine's not going to be detonating, or at least I hope it wont. My setup is SAFC, hacked MAFS, 450cc injectors, pump rewire, and freemods. I was wondering if you think it's safe for me to pull the knock sensor from the block and put it elseware, or if there's a way I can disconnect it. I dont think I have to be worried about knock at 17psi on race gas, but I could be wrong. My sensor is currently knocking way more than it should, I'm talking 48counts at constant speed, it's defiantly broke/old. Any opinions/ideas would be awesome.
I wouldn't go without it personally, that how the PCM determines where ignition timing should be. Try a local junkyard, they'll probally let you have one for $5-$10 bucks. Either that put in your pocket and tell them you didn't find what you were looking for.
You're hoping your way to a place called Sintered Pistons City.
Do not even consider running without the knock sensor.
Get a new sensor and revised lifters. Dirty old style lifters could be logged as phantom knock...
In fact I think that is probably it as a simple piezo knock sensor will outlast most any sensor on the motor...
  • Wanted 6 bolt NT water pipe
    • chrisman287
