damentor
- 81
- 0
- Feb 24, 2003
Milwaukee,
Wisconsin
Hello,
I am currently experiencing a situation with the ride(check profile for car info). Anyway, take a look at a some of the log below. A couple things....Shouldn't my o2 be cycling throughout the data there, also that timing is way high if I understand things right. Should I up the boost a bit and that'll drop the timing just as long as it isn't knocking?
Mind you this is with a brand new mitsubishi o2 sensor and mbc set at 16psi with no boost leaks. I was going to do a WOT 3rd gear pull but the trims are pegged at 118.6% and the Timing is sky high and the o2 is acting weird so I didn't want to risk anything. Let me know your thoughts...(Bad ECU?) Thanks in advance.
Log Showing Idle:
TIMA O2-R TPS RPM KNCK
8° 0.00V 10.2% 750 0
8° 0.00V 10.2% 781 0
9° 0.00V 10.2% 781 0
Cruising Log:
35° 0.00V 28.6% 3469 0
35° 0.02V 28.2% 3688 0
36° 0.08V 10.2% 3406 0
40° 0.08V 10.2% 3000 0
39° 0.16V 10.6% 2625 0
38° 0.74V 41.2% 2969 0
32° 0.06V 42.7% 2656 0
28° 0.02V 43.5% 2250 0
26° 0.02V 43.9% 2438 0
27° 0.02V 43.9% 2563 0
27° 0.02V 43.9% 2625 0
28° 0.00V 36.9% 2750 0
[Extra Notes: Wiring is clear from the exhaust and from being melted. So that looks all good. I got similar readings with the brand new bosch I got from napa and put in there about 2 weeks back before I replaced it with the new one saturday.]
Log Showing Idle:
Cruising Log:
