cudadrt
- 110
- 18
- May 9, 2008
Maryville,
Tennessee
Have been through countless posts and all lead to having head checked and milled. The first head I had on it was a 1G that I bought already done and was said to be surfaced but it wasn't smooth...looked like someone used a cheese grater on the finish. This lead to coolant leaking out all around the head so I got another 1G head and had it checked for cracks and machined flat. I reinstalled the head on my 95 Talon TSi 7 bolt block with a 3 layer MLS Cometic HG with ARP head studs and a light coat of copper spray on both sides of the gasket torqued to 85 ft./lbs. I have changed the oil twice now and still getting coolant mixing with the oil. I read on one post from a few years ago that it could possibly be the oil cooler but most posts I read about the cool said that oil would be in the coolant and I have no oil in the coolant...just coolant in the oil. I change the oil and run it for about a half hour a day and then a couple days after that and check and slowly see signs of coolant getting in the oil. Is it possible to be getting coolant in the oil from the cooler? I have a 6 bolt 90 air-to-oil cooler housing that I was wondering if I could use on the 7 bolt block? Also how many times changing my oil would it take to possibly get all the coolant out in the case that it's just left over coolant from the previous head? Car is apart as it's about to get painted but driving it up and down the road a short ways it seems to run strong. Compression is also good at about 170-175 across all cylinders. Any help would be greatly appreciated and I greatly thank you.
P.S. In case you missed the beginning...the head has been checked for cracks and milled flat and all good. Also have a "NEW" HG with new arp studs. This is driving me insane and really want to get this remedied.
