kspharris
- 478
- 5
- Aug 9, 2005
Goodlettsville,
Tennessee
Ok someone please tell me again where every spot on our car that oil can get into the water. I have been through this and been through this with my car. It is under warranty and the first time it did this they replaced the oil filter housing and it still did it so they replaced the T25 and it stopped, for awhile. This time they replaced the head gasket and had the head checked and put it all back together and it still does it. Plus with the car at idle it sits below 10 and it used to sit about 18 in vaccuum. So what do you think about where the oil gets into the water? No water gets into the oil. What do you think about the vaccuum situation, timing? How often does or how prone to failure is the oil filter housing? I change the oil myself and always go 1/4 turn past hand tight. The last time I changed the oil I may have tightened a little to much because I was distracted. Is there a way to check the oil filter housing? Thanks in advance and let me know, Keith.
