Water Pump Replacement
Jman9912
46
Apr 20, 2006
Conover, North Carolina
I've been searching around a little and got a few answers and information as well, but I figured i'd make a post about it to see if I could get more information.
My water pump is leaking like hell, so it's time to change it. I've got the water pump and all. From what it looks like, I can remove the motor mount and jack the motor up on the drivers side and replace it without having to remove the timing belt. Is this the case? Does the timing belt absolutely have to be removed?
