water pump replacement??
philipkrotch
Banned Member
904
Feb 9, 2004
butler, Pennsylvania
when replacing the waterpump...what all has to come off that deals with the timing belt?
Strange you should ask - I'm doing one right now on a '95. If it's the same as a 2g dsm: all belts, water pump pulley, A/C belt adjuster pulley/bracket, the alt. arm, harmonic balancer pulley, left engine mount, timing covers, timing belt tensioner (it covers a water pump bolt), timing belt.
It's also a good idea to replace at the same time the timing belt and it's 2 idler pulleys, and balancer shaft belt and it's idler pulley.
funny u said that..LOL. i just replaced the timing belt...twice. first time i replaced it and the balance shaft belt. well to say the least the balance shaft belt broke and i had to replace the timing belt again. i said #### the balance shaft belt and just left the balance shafts sitting there. well, now that i just replaced the timing belt, my waterpump has started to leak and make funny noises. DAMN. LOL
