Water Pipe O-Ring Replacement(Thermostat Side)
95AWD6Bolt
504
Dec 2, 2006
South Jersey, New Jersey
I just finished installing my PTE 50 trim turbo. I had to dent the water pipe to enable the turbo to snugly fit. In doing so, I think that I unseated the O-Ring in the water pipe on the thermostat side as it is now leaking on that side when I put coolant in.
My question is if I have to remove the entire pipe, turbo and manifold to replace the O-Ring? Or can I just remove the part that the pipe is connected to on the thermostat side and save myself a ton of time?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
