Water line from block
saechao04
462
3
Aug 8, 2006
portland, Oregon
Hey guys, I searched and found this picture. Anyone know what part number or thread size this is? Thank you.
<left>
<a href="http://s265.photobucket.com/albums/ii229/nsaechao85/?action=view&current=img0005tf3.jpg" target="_blank"><img src="http://i265.photobucket.com/albums/ii229/nsaechao85/img0005tf3.jpg" border="0" alt="Photobucket"></a><br /><br />
</left>
14mx1.5x whatever you need.. It is a bonjo bolt on a stock application.. I plugged mine for a big comp cover..
Edit: wrong thread pitch whoops. Fixed
LOL i lied i hope you get this... It is 14mx1.5x ect...Ill pm you to make sure you get this
Hey guys, time to revive thread. Got the right thread size thanks to viper, but the hose I'm using is rubbing against the turbo housing and/or is cracked, thus making me leak coolant. I was wondering if anyone knew the oem part number for this water line and fitting or something like what is in the first post. On mine I had to use an adapter, I think that's why I'm having clearance issues. Thanks.
<center>
<a href="http://s265.photobucket.com/albums/ii229/nsaechao85/?action=view&current=DSC_0290.jpg" target="_blank"><img src="http://i265.photobucket.com/albums/ii229/nsaechao85/DSC_0290.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s265.photobucket.com/albums/ii229/nsaechao85/?action=view&current=DSC_0291.jpg" target="_blank"><img src="http://i265.photobucket.com/albums/ii229/nsaechao85/DSC_0291.jpg" border="0" alt="Photobucket"></a><br /><br />
<a href="http://s265.photobucket.com/albums/ii229/nsaechao85/?action=view&current=DSC_0292.jpg" target="_blank"><img src="http://i265.photobucket.com/albums/ii229/nsaechao85/DSC_0292.jpg" border="0" alt="Photobucket"></a><br /><br />
</center>
Is that water supply or return for the turbo?
That would be the feed/supply. The return runs to the water pipe.
Thanks for the reply!
I have a 2g 4g63 nt and i'm currently putting a turbo on it.
I have a similar hole in the block, buts there is barely any water coming through the turbo when i start the engine.
Is that because the engine is cold ant the thermostat is blocking the water flow or is something else wrong?
The engine being cold would be my guess. With the thermostat closed, the water pump can only pump whatever amount of water is in the water pipe at the time into the block (thus into the turbo). I wouldn't worry about it.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
