Wastegate?
They are the valves that release built up pressure produce from your turbo. Our cars come stock with internal wastegates mounted to the turbo. They have springs which keep their valves closed but once a boost limit is reached, they open and stop the turbo from building more boost.
And yes, every 2g comes with them from the factory.
thought a BOV was for that -_- .... i am noob
A blow off valve (aka diverter valve or bypass valve) vents pressure from the intake piping when you let off the throttle. Otherwise the air will try to flow backwards past the turbo and cause surge.
A wastegate bypasses exhaust gasses around the turbine to control the amount of boost generated by the turbo. Otherwise your boost would continue to climb until something failed.
Only turbocharged DSM's have them. The NT models do not need to vent pressure or regulate a turbine- They have no turbo.
Edit- Lawrence, we seem to be on the same page. :)
What I came here to say :D
well this is why i am going to uti in july LOL......
Not going to help in this area..
Edit: Tree'd! ROFL
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
