Wastegate issue
95tsiemad
219
Sep 23, 2009
Cleveland, Ohio
Hi I have a 1991 eagle talon need to know what spring I need to use for my external wastegate my mods fresh rebuild 0 miles NPR pistons bored .20 over with a torque plate decked the block and head polished crank new bearings 1 mm oversized valves rc 550 inj stock fuel pump greddy 18g safc side mount compression ratio is 8.5.1 reconditoned rods arp rod bolts and head studs oem head gasket new oem water pump and oil pump balance shaft removal etc. How much boost should I run what fuel pump it's my daily driver
You'd probably want an AFPR at some point (don't know if your stock regulator can handle the flow), so after that, I'd just get the 255 HP and call it a day. Be sure to wire it so it gets the voltage it needs, too.
Go to the VFAQ main page, then to Fuel on the top navigation box, and on that page you'll see six guides to the right of "Fuel Pump Rewires". I'd suggest giving them all a read so you'll know how best to go at it.
