wastegate flapper siezed shut!! wtf??
crash89
3,543
195
Mar 5, 2008
Punta Gorda, Florida
alright so ive recently been having some overboosting problems which is making me have some massive fuel cut. I tried putting a mbc on to see if that would help my problem, no such luck. so today i went and took my wastegate off to see if it was damaged and maybe not opening properly, the i went to move the flapper, yea wouldnt budge!
what you guys think I could do? would just putting some wd40 on it and moving it till it works fine or what? I have a blown 14b, should i just swap exhaust housings? any advice would be great. thanks
Try removing the actuator and see if you can get the flapper to open using your hands, if its not stuck against the housing, then it could be a bad actuator
Like mentioned above, if the car sat too long, my have some build up keeping it from opening....gently tap it to see if it loosens....try and pry it....shoot some pb blaster or wd40 in there and gently tap it
