Washer Fluid Light
jarero
30
May 18, 2005
Pullman, Washington
Heres a fun problem for all you troubleshooters!
Whenever I make a left hand turn at any speed my low washer fluid light comes on, as soon as I straighten the car out it goes off. I can get this to repeat every single time and yes I checked the fluid level and filled it up. Any ideas where to check?
Thanks
Thanks defiant, I'm sure you will find it no surprise that I opened the hood first, looked around for a bit and then remembered the whole fill it in the hatch thing.
You might try cleaning the float. It's pretty easy to remove. Sometimes solids from the fluid can build up and prevent it from moving freely.
Thanks for the help, I will check the float and double check the wiring and see what happens.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
