2G Washer Fluid Light Always Stays On.
EagleTalon24
129
Jan 1, 2010
Seattle, Washington
I have a 2g 420a. My washer fluid is topped up on the front and rear. I tried disconnected the sensor but the only thing that did was turn off my washer fluid spray while leaving the light on.
Any suggestions on how to fix this? I don't want to just remove the bulb
It's surely just the sensor. I can see it as being annoying tho
You should pull the sensor and make sure the float moves. Some washer fluid contains a chemical that gums them up and prevents it from moving with fluid level changes. I've probably replaced over 75 for that reason on many different cars when I worked for different dealers. I literally just cleaned my Mazda 6s for the same reason last week. Brake cleaner works.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
