Window washer fluid dash light
DropSomeMoney
84
Feb 15, 2013
Rockford, Illinois
Why does my window washer low fluid light come on when I'm driving? Seems to come on when I get into the gas a little hard. Anyone else ever had this happen?
No. Washer fluid is full. This is the weirdest thing I've ever encountered with a car. Just wired!
*wierd.
Maybe a sensor? I don't know. Maybe I'll just disconnect it totally.
The sensor may have a bad connection and certain angles or force on it is causing it to freak out. Seems like a good place to start looking.
Like it has been mentioned, check the connector. I have seen countless DSMs with corroded connectors for the resivoir. Clean it up and you should be good to go unless there's a physical problem with the wires.
If the connector looks fine and not corroded, you can make sure the prongs are making contact with each other. You might have to stick a small screwdriver or pick into the female end and bend some prongs slightly inwards.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
