Warning Lights Don't Work
nfljohnl
79
Feb 19, 2010
Oceanside, New York
Whats up everyone I have searched this for a while and could not find any help. So my warning lights are all out except my door ajar light and my emergency brake light. My check engine light and my brights light and all the other warning lights do not come on when the key is put to on. All of my gauge lights work like my speedometer my temperature gauge etc. I have checked all my fuses inside the cabin and in the engine bay. Any help would be greatly appreciated. Thanks.
Try pulling out your gauge cluster and check all the bulbs for the back light, also check the connection to the gauge cluster
Thank you very much, but every single warning light bulb? That seems highly unlikely that every warning light would be out except the door ajar and e brake light. Is there anything else I can do besides that? I will pull the cluster and check the bulbs, but if that is not it what else can I do?
Check the bulb connections for voltage, voltage and bulb doesn't come on = bulb, no voltage to all of the cooresponding bulbs = fuse/connection issue. Trace the wires ALL the way back until you get voltage and resolve the issue all the way back up.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
