1G WARNING!!!! Front Lower Control Arms; Dorman vs. Raybestos
Most 1g lower front control arms are about 20 years old by now and have seen their fair share of wear and tear and either need to be serviced or replaced. There are a few replacement options available greatly varying in price, quality, and serviceability that I am going to discuss in this article. The options I have experience with are new Mitsubishi OEM, Dorman, Raybestos, and used OEM from a junkyard or classified etc. All new control arms come with pressed in balljoints and new bushings. All turbo 1g lower front control arms are the same for every model and are interchangeable from the years 1990-1994. New Mitsubishi OEM control arms are very expensive averaging around $250 a piece. I've found them "used" in junkyards and in classifieds for under $50 a piece. In my experience, Rock Auto, RockAuto Auto Parts, usually has the lowest prices and fast shipping so I will be using them as a reference for aftermarket pricing in this article. Dorman and Raybestos both make aftermarket replacement control arms available through Rock Auto. The Dorman lists for around $60 a piece, and Raybestos for around $160 a piece.
Recently I purchased a set of Energy Suspension lower front control arm bushings to replace the worn out stock bushings on my car. Since I was removing the control arms for this procedure I decided to go ahead and replace the balljoints and swaybar endlinks as well for preventative maintenance measures. At this point I was just planning on servicing the existing control arms because after visually inspecting the control arms on the vehicle they appeared to be fine. They were not bent and the visual rust was minimal. Unfortunately when I removed the control arms and pulled the large stock rear bushings off of their shaft spindles this is what I found in the picture below.
The bushing shaft was completed corroded and pitted from rust due to water entrapment. This is a common problem for 1g control arms due to the poor design of the stock bushing. The inside of the stock bushing is ribbed instead of being smooth, thus creating airpockets or spaces in between the mating surfaces of the inner diameter of the bushing and the outer diameter of the shaft. When moisture gets into these pockets it becomes trapped and eventually rots out the inside of the bushing and also destroys the surface of the bushing shaft. At this point the control arm is non serviceable and needs replacing.
Money is always an issue so I started out at the junkyard. Unfortunately all the 1g control arms I found basically looked similar to mine. Since this is an integral part of the suspension I decided to just bite the bullet and buy brand new control arms. The cheapest ones I could find were Dorman control arms from Rock Auto. I ordered them and when they arrived I closely examined them. Right from the start I noticed big differences between the two control arms from Rock Auto. After doing some research I found out that Rock Auto had accidentally sent me a left Dorman control arm and a right Raybestos control arm. The Raybestos control arm was like $100 more expensive than the Dorman but I still received it at the Dorman price so I wasn't going to complain! Haha!
Upon examining and comparing these two brands of control arms I was shocked and dismayed at what I found. The Dorman control arm was inferior to the Raybestos in every way shape and form. The Dorman welds were tiny and scarce and the balljoint was clearly not as stiff in its pivot as the Raybestos. The Dorman's rear bushing shaft spindle is what bothered me the most! Check out the picture below.
This is a top view image comparison of the two control arms. Notice how the space between the bushing stop and the control arm body on the Raybestos is completely welded. The weld is beefy and full just like OEM quality. On the other hand the Dorman completely lacks any weld in this area at all! The next picture is a comparison of the underside of the two control arms.
Look close on the Raybestos where the bushing shaft enters the control arm body. It is actually larger in diameter from the bushing stop back, making it stronger than the smaller shaft on the Dorman. The interior welds of the Raybestos where the inner shaft is welded to the inside of the body are beefy and plentiful, just like OEM quality. The interior welds of the Dorman inner shaft, or lack there of, are laughable! I couldn't get a good picture of them but you can clearly look inside the control arm body and see that the bushing shaft of the Dorman is hardly even welded!!?? Next is a picture of the Dorman bushing stop.
Refer to the arrow. Basically the bushing stop on the Dorman is just a large washer slipped over the shaft and held in place with a single spot weld! Absolutely ridiculous! The horribly placed spot weld won't even allow you to properly seat the bushing because the weld won't let it rest upon the stop! Also its one spot weld to hold the stop in place? I could have easily broken the stop away from the shaft by hand if I tried! The Raybestos shaft and stop are all one piece of either cast or milled metal, it's not going break.
At this point I've already decided there is no way in Hell I'm going to put this piece of crap Dorman product on my car, but for educational reasons I decided to further investigate its quality. First I burnt out the smaller front bushings on both the Dorman and the Raybestos control arms. After cleaning out all the rubber debris and lightly polishing the inner surfaces of the metal sleeves, I pressed the Energy Supension bushing into the Raybestos. It fit great!!! Nice and tight! Next I did the Dorman, total failure! The inside diameter of the front bushing housing on the Dorman is too large! The Energy Suspension bushing was completely loose, not even a close fit!
Next I decided to see if the Dorman balljoints were serviceable. I started to press out the Dorman balljoint and in the process it pressed out way too easily! It hardly took any effort at all to press it out, another red flag! I had two Moog replacement balljoints from the start of this project so I grabbed one and went to press it into the Dorman control arm. Once again total failure! The Moog balljoint easily slipped into the control arm by hand, completely loose, there was no pressing it into place, the opening on the Dorman arm for the balljoint was way too large! I've read posts on this site before where people have gone to replace balljoints only to find out they have been welded into place? Well I guarantee you its probably because sometime in the past their control arm was replaced with a Dorman, and then the crappy Dorman balljoint failed and when they went to replace it, to their surprise, it wouldn't press in and was loose so they had to weld the replacement balljoint in place to secure it.
Next I decided to check the serviceability of the Raybestos balljoint. The balljoint was extremely tough to press out, which is a good thing. The Moog balljoint pressed in perfectly! It took a lot of effort to press into place. I'm 100%positive that the Moog balljoint is properly seated and safely secure in the Raybestos control arm.
In conclusion, Dorman control arms are basically 100% non-serviceable without jerry rigging or modding. I don't even think they are a safe part to put on your car at all, especially if you have upgraded your suspension or lowered your car. If you're even thinking about installing Dorman control arms and racing I really hope this article deters you from it. The Raybestos control arms were serviceable in every aspect and had the same exact quality of OEM and about $100 cheaper. The Raybestos is definitely a quality product and in my opinion the best alternative for a replacement control arm.
Not too long after writing and posting this review, a represenative from Dorman Products contacted me. This is the message he left me.....
Hello JoOse -My name is Derek from Dorman. I must commend you in your notes and analysis. You were very descriptive and provided us keen insight for us to think about. I should assure you, we are a committed company that prides itself in listening to its customers. It is from your article, that we have decided to improve the manufacturing of this part so that the design will now be comparable to that of the OEM’s. In conjunction, this part will be backed by a limited lifetime warrantee, something that many competitors can't offer. We want to ensure that we are doing our due diligence. As an appreciation of your efforts, I would like to thank you and offer a free Fuel Line Repair kit (part #: 800-300) as a token of my appreciation, a $250 value. Please feel free to contact me should you have any further questions. Please send me your address so I can send you your package. Thx, Derek Suen Dorman Products 647 887 3321 [email protected] Dorman Products
I truely hope that Dorman follows through with the changes to our control arms. I've asked them to please keep me posted on their progress. Any feedback I hear from them, I will post on this thread. I don't know if Dorman will really do anything at all, but at least they've acknowledged the problem and have tried to compensate me for my trouble. Only time will tell. It just goes to show that writing reviews on product purchases pays off sometimes. So keep writing reviews on your purchases, hopefully we can make a difference.
That's pretty awesome that they are having someone/s looking for feedback on products. Perhaps he just happened to stumble across it accidentally. That does go to show some serious customer support!
I know right! I didn't contact Dorman either? They must have people who scour the web reading reviews and looking for feedback. It really makes me feel good that my review might actually make a real difference in how Dorman control arms compare to OEM quality and design. Dorman products also joined the DSM tuners forum and became members as a result of my review haha! Maybe they'll become supporting vendors one day? Your right though LIQUIDx, that's one heck of a customer service department!
Update from user leepen.
These are the Dorman CAs I received today, with improved welds thanks
Received a set of Dorman arms from Rock Auto a cuppla months back for my 91 Eclipse project and mine look just like the OPs set from the start of this thread. Must be some really old NOS parts judging from the age of this thread!
Since they're just sittin here in a box anyway I'll revise 'em myself by removing the rubber bushing that came on the arm and then grind off the tack weld on the face of the backstop/washer and remove it so I can do a bit of clearancing to the stamped steel metal of the arm so I can more easily weld in a fat washer to act as a support/spacer between the backstop washer and the stamped steel of the arm assy.
Then I'll just put some grease between the new washer and the old one I cut off and then between the old washer and the new urethane bushing that will be going in and let it float on the spindle so it can rotate when the arm moves instead of rubbing against the bushing as it was designed.
'Course then wire wheel it all and throw some primer and paint at it once the rework's done.
Not exactly something a purchaser should have to expect to do before installation but after the modifications it should be on par with the rigidity of the stock part and in a lot better condition than the bent and pitted ones on the car now.
I'm a professional auto tech and I occasionally make the Dorman mistake. I usually end up with their products because they are so readily available and often times only available otherwise from the dealer for much more money and longer delivery times.
Their products don't last. They are good about honoring warranties, but you better believe you will have to use it. Certain items like HVAC actuators you are lucky if they even work on day 1, let alone a year later. Other items like the 3 remanufactured hybrid batteries I tried using (with prices around $2,000+). All three came back with problems shortly after the 1 year warranty period was over.
Try explaining that to a customer who spent that kind of money on a repair they thought would last! Cooler lines leak in the first year. Never use their door handles or latches. The metal is about the third the thickness of OEM and they break or bend in the first year or so. I could go on.
If the Dorman Rep is still reading please tell your higher ups that repair shops would be happy to pay more for the product if we could trust it. Their part coverage and availability is amazing, but quality is absolutely the worst. It will take a lot of improvement over a long time before I'm convinced though.
Who makes a good OEM style control arm now? My right is shot and is preventing me from properly setting alignment.
Did you find a good replacement, 'causemy left ir rotted out completely and i haven't found any (oem or any for that matter) replacement
I bought a Dorman control arm for my 1G last year and it was identical to my OE arm. No bad welds or anything. Avoid the Mevotech arms. They are not identical to OE. The bushings are different and you cannot swap poly bushings onto them.
This is one I got off Rock Auto earlier this year.
Doesn’t look bad, does say it was made in China, but it beats nothing.
  • For sale 1g 1GA Flip Up Weather Seal Set
    1GA Flip Up Weather Seal Set $25 + shipping and paypal fees* rubber seals are in great shape...
  • Wanted 1g throttle 91 to 94 60mm
    Im looking for a working throttle body or in decent condition. Its for the 1g intake, i did a 6...
    • Josedsm
  • For sale 4G63 COP Setup ( JMFab Plate & 300m Coils )
    COP Setup $185 + shipping & paypal fees* JMFab Plate & 300m Coils * 91-99 connectorYou must...
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • For sale 1g 1g awd slave with braided line
    Stock slave with a braided line. Slave was a new OEM unit on one of my 1g’s. Good condition...
