walbro fuel pump
you think the walbro is loud..i use both the walbro and hrcs inline fuel pump and belive me the inline is much louder...but i got use to it.
Yes its loud, but at least you know its working, cause when you don't hear that sound that could spell trouble.
Why do u need both?
Why do u need both?
yea its loud compared to the stock one in the sense that i never noticed the stock one, i can hear this one. he uses both because you can flow a lot more fuel at higher pressures with both.
Looking at GsgoinFast writeup........sorry for using your pic man.......I didnt use the rubber hose. I used the 0 ring and other little parts like described to do in the instructions. I just dont want to mess anything up thats why i ask if its ok that i didnt use the rubber hose but the stock parts from the stock fp.
Why do u need both?
like GSGoinFastt said it does help me flow more fuel at higher pressure..i rather be safe then sorry..i've ran 15 psi of boost with my setup before and my fuel pressure was a lil over 100psi..the walbro alone would not mantain that high of a fuel pressure.
