Walbro fuel pump
black4banger
48
May 22, 2005
Pharr, Texas
Walbro fuel pump was installed ran with turbo (havent boosted yet) and i had 87 octane so i waited till i finished that gas to put 93 octane...after i put 11 gallons of 93 octane and drove around for 6 miles to stop at a corner store the fuel pump wasnt turning on and well the car doesnt turn on. Just my luck what could be wrong.
Weird thing happened. I got the car pulled to my house since it was at my gfs house and when we got to my house i put the key in and attempted to start it. Car turned on!!! wtf! THe fuel pump wouldnt even turn on when it was at my gfs house. :confused:
sounds like a short. pull the pump out again and check all the wires... thats the last place you want shorts... shorts = spark + gas = :notgood:
Check the relays and fuses too. Make sure their all pushed in good and tight.
My freind had the same problem with his s10 after he notched the frame and one of the grounds for his fuel pump wasn't tight cause it would work sometime not others
