1G W4a33k1up6
15143226
39
7
Jan 13, 2019
Sheboygan, Wisconsin
I just bought a transmission for my mirage build that was already upgraded and the code on it is W4A33k1UP6. The one that came out of my old talon was W4A33k1UPQ2. I found a website that seems to list most of the 1g and 2g trans codes but didnt see the 1up6 on the list anywhere and im hoping i didnt stupidly buy a jdm transmission that wont fit my torque converter.
Sure, no problem!
You have the same transmission that I just had rebuilt :)
Marty
Sure, no problem!
Marty
Sort of related question. Would you happen to know if i would have issues with this transmission and the kiggly 6 bolt in a 2g? I know all the transmission bolts are in the same spot but the 1g transmissions i believe had the 2 front and rear "motor mounts" on the engine block instead of the transmission like the 2g w4a33. And also that kiggly kit moves the starter location a tad. I will also be using the torque converter out of my 2g do you have any idea if i will have any fitment issues?
You are correct, the 2g trans has the motor mounts on it. If you want to use it, the Kiggly kit has all the parts I THINK. It DOES move the starter a fraction, so go with their advice.
