Vrsf j pipe install questions.
onefast2gdsm
866
6
Aug 30, 2010
millersburg, Pennsylvania
For the people running the vrsf on 1g or 2g, what kind of bolts did you use on the j pipe? Also, did the couplers that came in the kit work with the j pipe? None of the couplers in my kit fit the j pipe yet there's a t bolt clamp for it, that doesn't even fit over any of the couplers..
Use the oem bolts, and everything should work with the kit, t bolt is used on the smaller side of the coupler, i just called them to help you out.
There is no "smaller side" of any coupler. Every coupler measures 2.5 inch diameter, the j pipe is 2 inch diameter, and there is one t bolt clamp smaller than the others, which I'm guessing is for the j pipe. Doesn't help tiago doesn't answer messages. I guess I have to buy a seperate coupler. Thanks for trying to help though, I appreiciate it.
They just answered for me, they said everything should be there, if not i would call them back since you spent your money already, no point in spending money if you dont have to. Tell them your problem, they should be able to resolve it. Do you have pictures. 2.5 couplers sounds correct for piping and inlet on the fmic is it the wrong size?
Just got in touch with tiago, and feel like a complete dumbass. I had the pipe that connects to the j pipe flip flopped, I thought the 90 elbow went in a different spot, that's what I get for not looking at that coupler..thanks for the help and sorry for the confusion
