GVR-4 VR4 engine sputtering
dsmania17
5
Jan 17, 2017
sunrise, Florida
I start the car and it sputters like a misfire so I have checked everything and all looks good, so I disconnect the battery for a few minutes plug it back in and the car runs normal like nothing is wrong when I get to where am going and started up again sputtering misfire again I have to unplug the battery to get it running correct again. Does anyone know why this could be happening.
What tuning solution are you using? Is your mod list accurate?
yes list of mods is current, i opened the ecu and everything looks clean, when i get home today am going to swap airflow meter and see if ti fixes it also the tcu am going to change it and see what it does it helps when i have perfectly running gst that i can interchange parts from.
Is it still running well right before you shut it off? Only when you start it later does it act up?
I was thinking perhaps, by disconnecting the battery, learned values like trims are reset and that's why it runs fine after.. like when an o2 sensor starts going out and throws closed loop fuel off the mark. But if it runs great before shutting it off, that's potentially a different story.
Hello to all so this morning on my way to work am at a light and smoke starts coming out of the hood i pulled over open the hood and is the freon being released, not sure why this happened when i get home tonight am going to check the fan unit and also i hope the car doesn't over heat with just one fan in traffic. Any thoughts what could have done this.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
