Venting to atmosphere
They need to be recirculated unless you are running SD or a MAF-T.
With the stock MAF, the ECU is expecting that BOV to release air back into the intake. If you dont recirculate it, your ECU will be sending X amount of fuel thinking that additional air is also in the system.
BOV before MAF - doesn't matter. Vented, recirc, or comb
BOV after MAF - best to only recirc. Not vented or comb
SD - again, doesn't matter.
+1 to fourg. Keep it completely recirculated.
Even with a setup that lets you VTA without issues, I've heard a few people say the car still ran better when recirculating.
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
