Valves Not Sealing
Status
Not open for further replies.
andrewjscott
326
3
Oct 16, 2004
Sidney,
Well, I had to get a new head as my old one was cracked. The new one arrived and I put my lifters, and rocker arms and cams in it (came with valves, springs ect). but when i torque down the camshaft caps, the valves stay open, in all cylinders, nomatter what the cam position (the valves do move, they just don't completely seal). There is about 10 thousandth gap between the valve and the seat. I don't think this is normal, and any opinions on what to do would be great.
I had the exact same problem as you. Turns out, over time, they will seat properly. But it was because of the Hydraulic lifters. They get hard, and don't compress/expand like they should. So instead of chancing it and letting mine seat over time, I bought some new "3g non-ticking lifters. I primed them w/ a jar of oil and installed them. The valves then set immediatly, properly, and I didn't have to worry about them again.
So the problem is in your lifters, b/c they are old, some are getting hard and not moving correctly, thus causing the valves to not seat, b/c the lifter will no compress. Over time, constant pressure on the lifter will couse it to seat again, but replacing them is your best bet, and get some no-tickers too!
the lifters are out of my old head and they worked fine. They were only in my car a few weeks ago. Could they still be "old"
Also I'm pretty poor right now as this summer I had to:
do a rebuild
get new head (cracked)
clutch
and I just paid my tuition :notgood:
How much are the 3g lifters and where can I get them cheap. I'm in Canada so usually shipping kills me.
I also have another set of lifters available, should I switch those out?
well, it may come to that, but I really don't have the money so I guess i'll have to wait. There is not a difference in lifters besides the bigger hole at the top, is there? Like there is no difference in height...right?
I went back to go change the lifters and all the valves are right where they should be. I guess I am just not patient enough. Seems that the lifters settled and everything is fine.
Just like I had said. Hope everything works out w/ the head job.
Status
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
