Valve seal
Your engine will burn oil when sitting at idle after warmed up and then stepping on the gas to pull off, such as from a red light in town. You can also pull the exhaust manifold and look back inside the ports and see if there is used motor running down the valve guides leaving wetness inside of the ports.
