Valve Cover PCV & ECL
Anthony Yacullo
148
3
Aug 20, 2014
Reseda, California
So my check engine light is on and its an o2 sensor, and I also have p1105 (barometer something). Not sure what is wrong but it does idle different on start up. I also have no breather hose coming out of the valve cover, I just picked up this car and never had a hose. My questions are could this be causing p1105 and where does the hose hook up to, I know its somewhere on the intake but I can't seem to find it.
The open nipple on the valve cover will need a vacuum line going to your intake pipe just below where the bypass valve recirculates back in the intake. That source to the valve cover needs to see vacuum to relieve pressure which is why it goes to the intake (pre-turbo).
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
