vaccum lines all over the place where do they go
willnatale
53
Mar 15, 2012
west warwick, Rhode Island
Where can I find a diagram of the motor that tells me where the lines go the car started but I want to make sure everything is where it goes before i start it again I got a 92 tsi
You can type in (vacuum line diagram 92 tsi) either on yahoo or google and get plenty of pictures illustrating what you need, if not buy a chilton or haynes manual.
I bought the car not running I got it running with a know so I'm changing rod bearing and the valves Tommorow I got the car with some lines off but once I do the head and rods I want to make sure I get everything back where it should be my friend is a mechanic but me and him know hondas I'm new to dsm
I'm replacing the rod bearing ### I cranked the car over and it sounded like i had a know so I dropped the oil pan and the rods have some play in them so I'm replacing.them and if that didn't solve my problem I'm moving on to the head to check the valves
If there is play than the crank is damaged. New bearings will fix nothing.
There's a little play its not like a can shake them around but its off so I was going to change them
    • george bromwell
    • pma1123
    • Sdcryan1
