ECMlink V3 help (not starting)
dsm-junkie
277
Jan 20, 2012
miami, Florida
Hey guys I just got my link v3 up and running! I connected my 95 eprom ecu into my 97 2g and I cant get it started now! I bought the link used from a member. I decided to reset the ecu to stock settings so I could start fresh and start logging! I did swap the plugs around and check the box that says non 95/96 CAS. I will try and start the car and it will sound like its about to start. RPM's will jump to 1500 then they will just drop to 0 and the car will shut off! I do have a stock ecu and the car turns on fine without it! Is there something that I am forgetting to set on DSMlink??? Any help is appreciated! Thanks guys!
You don't switch plug wires with link it you have the box for non 95-96 Cas checked. You are basically bypassing the problem when switching plug wires and undoing the bypass by checking the box. Just uncheck the box OR switch the wires back and she should start right up.
I've tried a bunch of different arrangements with the plugs swapped and the box not checked and it still didn't start?? I'll go double check right now!!
Either start a capture with the key on or while you're trying to start it and post that log, or you can click on ECU config and ECU direct access and you should be able to go to File > Save and save a properties and direct access file that way.
Great thank you for the fast reply sir!! Ill give it a try right now!!!
Heres the datalog! Hopefully this works! I do use mac! I hope this isnt a problem!!
Heres the current settings that I have on link while trying to start the car!
According to your log, you have it set that you're running a GM MAF with the ECMTuning GM MAF cable. According to your profile that isn't true. That's probably your issue.
Oh man!! I'm gonna go check that out right now!!! I totally missed that!!!
IT WORKED!!!! :thumb::thumb::thumb: Here is a datalog of the car running!!
heres the log
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
