V3 DA tables vertical values unreadable.
mizak82
172
Jul 24, 2010
palm beach, Florida
I'm new to ecmlink v3, but the direct access tables for openloop max/min octane and timing max/min octane are cut off.. I cant read the Vertical values which are vacuum and boost I believe.. Is there a way to adjust that, its as if its cut off.. I expand the graph but yet the boxes still dont show the full values.. I see the horizontal RPM numbers just fine. any help would be appreciated.. at the very least it would be nice to know the values.. thanks
I would post a pic but I cant get it to copy.. Basically the chart looks like this:
750 1000 1250 1500 1750 2000 ect.
0.
0.
0.
0.
0.
0.
0.
1.
1.
1.
1.
1.
2.
2.
I can't seem to expand it..
So, the load axis column won't expand. In other words, you can't see anything after the decimal?
I doubt this will do anything but it's worth a shot:
Go to Edit->App Preferences->Look & Feel and try experimenting with the different window manager themes, e.g, GTK, Nimbus, etc...
What is your screen resolution? Possibly a really small netbook or something?
I thought about that too, but even then it should cut off the right side, unless the window isn't maximized and is moved over to the left.
OP - Do you still see the column at the far left that lists the DA pages?
This sounds like a platform/java/display issue methinks.
EDIT:
What is your OS font size set to? Some apps have issues when you set it to extra large fonts, but it should should show up in other places in ECMLink if so...unless they just forgot to code that one column of numbers to handle it.
I am on a macbook and had to change my java to get ecmlink to work originally.. My resolution is 1280x800 and can see everything on the left.. If you detach the table and expand it the entire screen the table doesn't expand only the white surround of the page.. Its as if the load column is a tab over and cutting off..
