MMCD EGRT Values
sapper12b
71
Mar 7, 2013
St. Robert, Missouri
My logger is constantly showing -607 to -610 degree EGRT. This doesn't seem right to me. Any suggestions. EGRT is blocked off.
There is nothing hooked up to it... Only Cali cars have a EGRT. Here is a screenshot of a palm log with a car with nothing hooked up below.
Did you mean the EGR is blocked off? Doubt you car has an actual EGRT on it... .
Your car is a 90 as well right? If so you would have a MD145902 Ecu (if stock) if it was a Cali car. Also you can't miss a EGRT underhood(well I couldn't).
Just use the input(pin 15 at the ECU) if it's not the ECU above to log something like a MAP sensor or Wideband.:thumb:
