upgrading brakes on a 97 eclipse gs
hillbillyboostn said:
will the vr4 caliber brakes work for the gs. how about the sl? which one says mitsubishi on it will it fit.
the SL will, i dont think the VR-4 do
The VR-4's will fit, providing that you buy new brake lines, because of the fittings on the end, one is a banjo fiting,a the others are different. If your smart you'll buy new brake lines anyways.
Steel braided brake lines
2 pistion calipers
cross/slotted GSX rotors
Shims (not needed though)
There is a guide in the tech articles of exactly how to do this swap and what will work.
2 pistion calipers
no no thats the SL's brakes. the VR-4 has 4 piston calipers and will not fit stock wheels, and you need at least 17's to fit them in there, plus theres more fabrication involved. just go with GSX brakes
so the sl says mitsubishi on them. got 18 inch so thats no prob. what are the sl 2 pistons? oh are the gsx 2 aswell?
yes the SL and the GSX are both 2 piston
