Unidentified Metal Objects
Evilimports
125
Dec 4, 2008
Elkhart, Indiana
So when i was tearing down my engine i found quite a few metal pieces in the oil pan. I thought once i had the engine disassembled it would be obvious where they came from but i could not find anything.
All that suff is too small to have anything to do with a piston land or rings. That pice that is broken up what is it made of? Looks like brass. Have you tried to reassemble it to see what it looks like put together? that round dick like pice looks sheard off. The 3/4 cresent shape part looks like a snap ring.
Strange that you motor was running when you found these things. In the pan.
Well basically when a turbo blows, shards of metal can go from the turbine wheel and exit through the outlet through the lower intercooler piping. Then it travels through the intercooler, into the upper intercooler piping and into the intake manifold. Then from there, you can imagine how it reaches the engine and ends up on the bottom of the oil pan. Usually happens when a person keeps running the car constantly for a long period of time (days or weeks), even after the turbo is blown.
Via the oil return line.
Option 2.
If Option 1 were correct then:
  • All that metal would have to travel UP through your side mount intercooler instead of just laying in the bottom. Those are some pretty heafty chunks.
  • You compressor wheel would be toast.
  • You'd have to have a huge hole in the backplate behind the compressor.
  • The metal would have to either sneak through a valve guide into the head, or around a piston and past the rings.
I dunno, you decide...
Well heres the short version of the death of my dsm. Car ran great, side swiped a curve at 70mph, got the car fixed and didn't really have as much power. Turbo started sounding weird, started burning oil like crazy and sound got worse. I never really drove it after that but i did take it out occasionally. It all makes sense, the turbo was the first thing i took off so i forgot about it and didnt consider it when i saw the metal chunks. The oil return line for the turbo is more than big enough for all those chunks to travel through.
