AW4G63
- 2,001
- 9
- Apr 11, 2002
TommyPantsdownville,
Ohio
OK, Well I have posted this in the past and im back again. I have a ongoing knocking noise clanking and clanking. I have been going nuts and done a few things to try to diagnose this problem.
Heres what happens:
Im Stopped
I put the car in gear and release the clutch and start to move.
A faint knock is heard (clunck clunck clunck) (only when torque is on the driveline)
depress clutch, sound is gone.
go to 2nd gear and release clutch, clunck is heard faster.
depress clutch, clunck is gone.
release , clunck is cluncking in 3rd.
depress clutch clunck is gone and shift to 4th.
Clunck is now gone or im going to fast to hear it (road noise, exhaust ect.)
-----also----After a month of this cluncking noise this started----
Lets say im in 4th gear low RPM and I go full throttle, as boost builds up and I start to really move once I get to a high rpm there is a large "POP"
Only at high speeds.
(4th gear 2,000rpm= vrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr"POP"rrrrrrrrrrrrr"POP"rrrrrrmmmmmmm , shift to 5th vrrrrrrrrrr"pop" rrrrrrrrrrrrrrr"pop"rrrrrrrrrr)
Sounds like it is coming from the front right area, but others who ride in the passenger side say it sounds like the rear and others say the front.
/\ hope that helped.
Things I have done to find problem.
Shaked front CVs
Shaked driveshaft
Didnt find exsessive play in either.
Just had buschur install a clutch & flywheel (act2600 & fidanaza alum fly)
I thought maybe it lied with in the clutch & flywheel but I was wrong.
I brought one of Buschurs guys for a ride yesterday but between my exhaust and pouring rain we could not hear much. But I didnt mention the "pop" because I thought the clutch fixed that, I found out it was still there on my 45 minute ride home.
Any thing you think could be a factor would be a GIANT help.
I think I may bring it back to Buschur to find and fix it. Those guys are very fast and great to deal with. And the fact that they know their shit like no one else sure does help.
This weekend Im going to check my U joints and anything else you think may be the cause.
Thanks guys.
Tom
I honestly have not a clue , Another member has this same problem, Im going to see if he will post here. Maybe between the two of us and some of you we can figure this out.
Heres what happens:
Im Stopped
Shaked front CVs
Shaked driveshaft
Thanks guys.
Tom
. My car has been doing this for like the past year, and only does it through first and second gear. I tried to figure out what the hell it was, but never could find anything. I figured id just leave it to see if the noise got worse or something would eventually break, but.. the noise hasnt changed at all and nothing has broken yet... *clueless*
(I've had all the recalls done on my car also, so im pretty positive its not a cv joint issue)
