UICP Q. ABS vs NonABS
chicagoavenger
981
13
Aug 17, 2004
Rio rancho, New Mexico
Just wondering how much of a difference a uicp for abs is to non-abs on a first gen. I see used 1st gen for $80-100 but there non abs and the abs are 2.25 as opposed to 2.5". I guess my q is if I get one non-abs uicp will it absolutely not work on my abs equipped car? I don't know anyone that has a first gen with non-abs uicp on to test fit. Thanks
my non abs pipe, goes straight from the ic to the throttle body, if you look under your hood, and go straight from the IC to the Throttle Body you wil see that your abs box is in the way.
there are abs uicps that are 2.5 inches, Extreme PSI sells one. not sure who else though
Pretty sure the important difference is the route. The ABS one bends around where the ABS is, the nonABS pipe goes THRU that spot. Check out dejonpowerhouse.com and you will see the layout is different. I think they make quality pieces at a good price, have upgrade all pipes/elbows with their pieces, no complaints.
Thanks I had a few people tell me it would fit but would need some elbow grease which didn't sound right when I heard that.
