Abs Uicp
LaN-
956
7
May 7, 2004
New Baltimore, Michigan
i know i could do this in the gallery for this but after 10 mins i gave up
can someone show me a picture of there 1g DSM with an aftermarket UICP with ABS and if you can a close up of the BOV. I put mine and one of the hard lines for the ABS are like dead on the BOV return i mean we have 1mm of space here, its almost like it was made wrong and the BOV needs to be turned. If anyone can help me out thanks if not its all good
Thanks,
LaN-
Here is mine (a De Jon Tool 2.25" UICP made for ABS 1G DSMs)... You can kinda' see the BOV in relation to the rest of it.
The only problem I had was finding a new BOV return hose... I ended up using a 90* bend that I cut out of some Toyota's upper radiator hose.
(Don't mind the gaffer's tape, it hides my thermal insulation)
http://www.dsmtuners.com/gallery/data/501/35594Underhood.JPG
