Uicp
fatafall
89
Aug 2, 2004
Lancaster, Pennsylvania
I have a 1/2 pipe 2g UICP from Dave Brode, and I want to complete my UICP with the Dejon Tool S-pipe that I found on turbo garage for $80. A couple questions, will this fit with my current half pipe? And can I find a similar pipe for less than $80, seems kinda pricey, but I guess it does replace my stock TB elbow, so it should be worth it. Thanks. :talon:
Thats a good idea, thanks for the link to that write-up. I thought it would be a problem if the ends of the pipe werent beaded, but if the couplers are tight enough maybe there wont be a problem. Def a better alternative to that $90 pipe. Thanks. :talon:
For beads you have three options...Find a local exhaust shop that can do flairs, put a ring of jb weld around the end of the pipe, or flare the end of the pipe slightly with a pair of pliers. The latter is the least pretty but easiest. I used pliers and my pipe has held up great.
Bob
