Turbonetics 62-1 too big???
Hi, everyone. I just taked off the manifold and the exhaust is a .58 p trim. I just notice that the exhaust ports on the head are ported and the exhaust manifold is not. Will this cause some problem???
It could increase tubulance dramatically right there yes. You could try to taper port the inlets to increase velocity into the turbine housing, and reduce the "step" you seem to have going on.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
