turbo xs mbc boost spike at fully closed
915GsT
32
Apr 16, 2009
El Paso, Texas
i just want to know if anyone else has had this problem.
i have a xs boost controller the basic one, im using vac source from t25, both vaccumm lines are maybe 6 inches long. the problem is that the mbc is turned all the way down to closed and even at that im boosting 11 lbs with spikes to 15.... any one have any ideas... i did do a vac leak test but everything seems fine..
thanks in advance.
well I was just saying that I just said screw it and got rid of my xs controler and bought a Hallman controler but you can also adjust your boost by messing with your internal wastegate if you have an internal wastegate. To do that you have to loosen the bolt at end of the shaft then turn it it think counter clock wise to turn boost down. I could be wrong tho, but im like 95% positive on that
    • Sdcryan1
