Boost range on a turbo xs MBC
cjridert1
403
6
Jul 4, 2007
Akron, Ohio
Ive never used a mbc and my buddy is having fits with his (just put it on). They are 1psi/turn correct? 12 is the max amount he said he could get out of it - are there different springs in these or is it progressively different? Thanks in advance!
What is the wastegate spring pressure?? That is what matters. Generally you can run 1.5x the the wastegate spring pressure. The MBC should not matter much.
This is true. I've gotten as much as 2x the wastgate spring pressure on my internally gated GT2871R with the same MBC but you will get some creep and it won't hold much past 2x. AS for 1psi per turn on the turbo XS MBC that is wrong. You should turn it all the way down and then back it off 2 full turns and you should be very close to the WG pressure. From there you can back it off 1 full turn and then test your pressure. From my experience it doesn't change much at first and then progresses rapidly after that. Be careful when you get past about 25% over your WG pressure. I wouldn't turn it more than a half turn until you reach the desired pressure.
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
