Turbo Won't Spool, Fuel Cut at 3,000rpm.
NOSEZJ
Aug 2, 2013
Clinton, Iowa
I'm new too DSM's and I need help!
I was driving to work one day and i shifted into 3rd and I heard something "snap" and the car died. It starts but the idle is a little rough and dies every time the clutch is released. I've installed a new turbo but when I had it out there was no boost, it was still dying, and when it got up to 3,000rpm it would'nt go any higher, it felt like fuel cut. I did a boost leak test earlier and there wasn't any. What should my next move be? :confused:
If you heard a snap? I would guess a coupler blew. If a coupler blew, you wouldn't hear it in the BLT, instead you have to check every coupler. Check compression on all cylinders.
I pullled the front bumper and the coupler on the fmic was off. It's running better but it idles funny, my rpms bounce from about 1,100-900 and when i let off the throtle it acts like it's going to die but shoots back up. Taking it out for a test drive tomorrow. I'm hoping this solved my problem.
