Help! Turbo won't spool, Egine stalls!
chrisfrye
122
Dec 17, 2004
harpers ferry, West Virginia
Alright I'm not sure what to make of this, hopefully someone does. It's on my 93 Talon TSI It started about a week ago everymorning early in the morning on my way to work i coudln't get my turbo to spool for the first 10minutes or so til it seemed the car warmed up suffecitently. I've been running around to much to worry about it, i never had any problems when it was "warmed up".
saturday mid day i went to start her and it kept stalling out immediatley or was hesitating, i went to take it for a drive and everytime i'd come to a stop or try acellerating from a stop it'd stall, and i couldn't get my turbo to spool the entire time, probably a 45 minute drive. now when i say i cant get my turbo to spool, i mean my guage is reading its in boost and its right with the rpms, but i have absolutely no power from it and it sounds horrible. i've had problems with my turbo spooling only a few times but its never lasted like this. i cant drive anywhere, i could barely climb the mountain back to my house.
I'm also throwing a check engine light. I tried to reading it using a voltimetere and on pins 1 and 12 on the connector down by the fuse block. using a digital voltimeter and trying to translate it to paper in realtime wasnt easy but when i tried to compare my results to the codes in my book, it looked like it threw almost every code listed, I have no idea how this could be. i figured it was irrelevant because i didnt see how i threw 10 sensors but if you want the information i'll go back out there and get it down again.
I'm not sure, any advice would be greatly appreciated i have no other ride to work right now and i can't seem to figure this one out. Thank you!!
Pull the ecu out and check for leaking caps and a damaged circuit board. Thats sounds like the problem if you threw that many codes. Eventually, it will get to the point where it wont even crank up.
Good Call, i should've takin the ecu reading more seriously. I assumed if the ecu was bad i would get a constant high voltage 12-13v. It's been years and years since i've worked with microboards but to my knowledge i dont know if its a capacitor that "melted" looks more like a transistor, melted everything around it, the boards slightly chared, i don't know if it's salvagable yet. i included the best picture i could take with the little digi i have/ either way it seems reasonable that that's my culprit. I've built pleanty of boards this simple years ago, i don't know how hard it would be to get the parts for this though or if itd be more feasable to get a new one.
I coudln't get the picture uploaded from my drive or from a website.. i put it up on my geocities
http://www.geocities.com/thechrisfrye/DSCF00731.JPG
Thanks 92awddsm
Yeah its definitely no capacitor that melted. from the reasearch i did i couldn't find anyone else out there that had their ecu melt here?? I dont know what the heck that means. This is an eprom ecu, i'd like to salvage it if at all possible. but i cant find anywhere where i could get the electrical parts i need to rebuild this. debating if i should goto a junkyard and pick off the transistors i need, and replace the capacitors and the couple resistors that got burnt while i'm at it. but i'm concerned why that chip got fried there... anyone with any ideas?
i have been having the same problem am going home today to look at the ecu and i tell you what i find,
Thanks for the link, i hit a couple more electronic shops. i found the one transistor i need m5269l.. the part i'm having problem finding is the "green box" to the left. looks like a power convertor of some kind. it also looks like where the "fire" started. its serial is 68k100 ncc.. i'd imagine its standard on just about every 1g ecu, thats why i was thinking about picking up a junk yard ecu
