turbo whistle but no shaft play or smoke!
boostedinthe843
307
Oct 22, 2008
beaufort, South Carolina
ok so yeah once i hit around 10 psi or more i get a whistle from my engine bay, i've done a boost leak test, pulled the intake and felt the shaft and there is no smoke. what could be the culpret. it sounds like its coming from right in front of the drivers console under the hood where the stock boost selenoids are, any ideas?
Is it really sharp/high pitched or more of a woosh/dull sort of sound? Sounds strange but it makes a difference.
Not sure the best way to check if your BOV is holding boost, but it sounds like it could be leaking under boost.
It would make sense that a normal BLT should show if it is a problem, but I am not sure on this. One time a shop checked my Tial with a vacuum deal, but it didn't quite make sense to me.
How much pressure were you using when you did your last BLT?
last i knew when a turbo spools it wistles, but you prob have an exhuast leak and its small so its wistiling past the gasket, check your o2 housing my car does the same thing sometimes due to the o2 housing bolts backs off
I had the same Problem with a 14b years ago. It would whine almost like a supercharger under load. turned out it had a barely bent fin that almost wasn't noticeable, turbo had no shaft play and didn't leak or smoke. In fact the turbo worked for years to come.
yeah thats what it sounds like. ima check that now, most likely the case
