kyler021
- 242
- 178
- Aug 29, 2023
Pasadena,
Maryland
Hey guys, as the title states, I'm almost completed my turbo upgrade. In the midst of that, I tried to prime the motor and turbo. I did this by cranking it up with and without spark plugs, fuel injectors disconnected, etc. While cranking, the oil dummy light did not go out, my AEM Gauge didn't go above 2 PSI (taken with a grain of salt because I've been having problems with this gauge). I hooked up a mechanical gauge and it did not move at all while cranking.
Things I've changed related to oil:
-Oil feed line for turbo (Head feed)
-Turbo
-Tightened up the oil cooler bolt (31 ft-lbs)
-Oil change including filter
-Gaskets for oil drain tube
-3/8 BSPT plug on filter housing to use head feed
-Cam position sensor O ring replaced
The car has been sitting since early December, so around 5 months. The car had high oil pressure when it was parked. Ran fine as well. I know the oil is correctly filled. I have tried filling the oil filter with oil (filter was dry beforehand) and still nothing. Any ideas guys? Maybe the oil pump is toast? (Can oil pumps go bad from sitting for such a short period of time???)
Thanks for any replies!
Kyle
-Turbo
Kyle
