turbo timer?
josherino
148
Sep 18, 2004
Ft Collins, Colorado
wondering what turbo timer to get, maybe looking for something that can clock 0-60 and 1/4 mile, anyone have any suggestions?
I've got the Apex`i TT in mine, but it doesn't clock anything. On the up side, it does show you your O2 sensor reading, to two decimal places, and will tell you if you're running rich or lean, if you hook up the O2 tap to the right wire. It's also very small, so can be mounted almost anywhere in the car. I've got mine stickytaped to the lower cover trim piece (just below the radio).
I think the GReddy TT will clock some times, but you'd need to look it up. It's also MUCH bigger than the Apex`i, and can be a real pain to mount.
In either case, you'll most likely be using the Trust TT harness. I didn't realize they made one for cars that came with the OEM alarm, so I got handed the non-alarm harness by RRE. Irritating.
i think G-Tech's are on ebay for like 50 bucks.
100+ for a turbo timer are waste of money. as long as youre not going balls to the wall then instantly pull over and stop the engine, youll be fine. if you go out and race, then drive normally for a few minutes, you are more than fine. moving and keeping the engine under little load cools alot faster than sitting in the driveway for 2 minutes at idle.
A turbo timer is a turbo timer. Buy one for it's intended purpose, not for bells and whistles. My advice is to find the cheapest one, whether it be GReddy, APEXi, HKS, whoever. Bells and whistles get old after a week, so you are much better off spending $50 to time your turbo, as apposed to a super-cool $150+ timer.
I spent ~84 on a Blitz turbo timer add 20 bones for the plug and play harness.
I installed it last night and it only took 20 minutes. There's a control module that you can hide back into your dash behind the radio or ecu, where ever. The timer display unit is sharp, pretty small. It has the additional features you were mentioning. I was impressed with the ease of install and also it's automatic fature. Some how it manages to set the timer based on engine load. I bought it from DSMparts.com just thought what I have sounds identical to what you're looking for. Here's a link with details:
http://www.dsmparts.com/customer/product.php?productid=297&cat=163&page=1
check ebay i got my greddy turbo timer and HKS harness for like 80 dollars(together from diff dealers) the greddy can be mount on top of the steering wheel hub or if you have a aftermarket cd player or the cd player that came stock with just the CD and not the tape it can go into the cubby hole with no problem and it does all that timing lik 0-60 80-100 0-100 and so on but you have to tap a purple and some other color wire but yea i would highly suggest the greddy if your looking for timing features :thumb:
alex
HKS type 1.
yea, i swear by the hks type 1. I bought it used for like 80 bucks a lil over a year ago and i love it. Has a lot of clockin features. Mine are all in metric tho.. I don't know if they make them for us measurements. any turbo timer is gonna keep your car runnin, but if you wanna be able to do some other stuff with it, the type 1 works pretty good; just can't vouch for any other ones, cuz it's the only one i've tried.
i have the blitz FATT DC..i think its a good turbo timer. Its small and it is automatic.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
